WidebodyZ »
https://forums.nicoclub.com/widebodyz-u41772.html
Sun Oct 22, 2006 1:48 pm
All you have to do is remove the radiator and fan to get more room to work, take off the hoses, then start to remove the pipes...after taking out the radiator and fan you'll have plenty of room with an extension to get to the bolts. Take those out and remove the clamps holding the two hoses on. Replace these hoses while you have them out. Then just pull/twist on them and they'll pop off. after they are off you'll easily see the thermostat. Might want to change the H20 pump while you're in there.
