heater core hoses? pics?
inkslingers13
Car: 1985 Corolla Gt-S
i have been looking all over the place and cant find a picture of the sr20det heater core hoses. i bought some and just dont see how they go. my motors going in and i want them on before it does go in. any pics would be great. thanks
17wantinga240
Car: 91 240sx 1986 toyoa cressida
i bought a set from my local auto parts store for way less then heavythrottle same exact design and they work perfect no kinks or nothing
T-rev
did you just get universal hoses or did you get pre-formed hoses?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Best pics I can find:Before:
After:
You would still need to get two hose step pieces that would have 5/8 on one side and 3/4 on the other.
inkslingers13
huh... that doesn't look like it would work. so there needs to be a u bend that make it flip around the other way to reach right? could i just cut the metal tube? and make it work that way? seems like people should have been doing that from the get go. where the metal tube make a 90 degree turn, cut it so its straight and use a tube that almost goes straight into the heater outlet?thanks guys
Kitswa
Turbo coolent return goes into that metal line - you would have to modify that unless you run S14 coolent return to water neck.
- Bill
inkslingers13
made no sense... the 2 metal tubes JUST go to the heater. my turbo is only oil cooled...
callmeweezy724
Car: 1990 240sx w/s13 blacktop swap, 1986 e30 325e 4dr 5spd,1997 infiniti Q45
wats the part number on the s-shaped hose i kno the u shaped is a gates 19666 but wuts the s shaped one?
240_SeX
Car: 1992 240SX SE
inkslingers13 wrote:made no sense... the 2 metal tubes JUST go to the heater. my turbo is only oil cooled...
If you dont need coolant to the turbo then your best but would be to cut it. The only reason not to cut the metal line is because the smaller line that comes off it for the turbo coolant feed
schanne
Car: 93 Hatch-Sr20
Can some one help me please. Those pictures are confusing me, there is hoses missing and changed around in the AFTER pic. I'm about to pull my motor in the next couple days and figured this would help. Please can some one help the slow one or are those pictures wrong?
koukiguy13
Car: 1995 S14 with S15 Motor- 2001 Lifted Chevy CrewCab 2500HD
Does it matter what kind of SR motor it is?(s13 red & black, S14 black, S15 black) I can show you some pics of the way I hooked them up but I have a S14 with S15 motor. I dont know if its the same as S13's.....
schanne
Car: 93 Hatch-Sr20
post em' up!! ^
koukiguy13
Well this is how I hooked them up for my setup. I used my stock s14 hoses with a little modification(shortened the hoses). Hope this helps.
