ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Jan 28, 2011 1:55 pm
Do not use compressed air without a regulator set to 15 PSIG, if not available use a garden hose but watch out for high pressure there too, some water systems can reach over 60 PSIG.
Turn on the car heater to the hottest, then purge out the coolant from the engine, run the garden hose through till clear. Then operate the engine with water only warm up, stop, cool, then completely drain and be sure the heater is drained,
Fix your problems as discussed elsewhere then fill the coolant system making sure the heater is set to hottest. Fill and vent then make sure expansion tank is at mark, test run. Cool next day check expansion tank and run heater full hot and cool then with AC on. Check around engine for leaks including Rad, hoses, vents.
