Okay, I seem to remember that from the original post.
I did a quick google and found this.:
"Ramsey Mesyef, ASE Certified Mechanic turned grad student...
Written Jan 5, 2016
First make sure your thermostat is working, that is a much more common problem than a radiator being blocked.
If you're sure your thermostat is working (either by carefully feeling the coolant hose coming out of it to confirm it is hot or going so far as to remove it completely as a test if it's easily accessible), then carefully see if the hose leaving the radiator is warm.
If your radiator is partially blocked and causing coolant to go through it more slowly than it should, the symptoms should be variable with outside temperature and vehicle speed (whereas with a thermostat it should be pretty much the same under all conditions). For example, it will be hotter sitting in traffic than at highway speed.
What is more common than an internally blocked radiator (though of course that does happen) is an externally blocked radiator where road debris and dried bugs are preventing air from passing through it and hampering its ability to cool things down. Visually inspect both the front and the back. If dirty, ou can literally take a garden hose to it and should notice a differnece immediately (if it is your problem). Even if it is not visibly dirty, make sure the air from the fan is passing through it to the engine side. And while we're on the topic of fans, make sure yours is working. That's also a much more common problem than an internally blocked radiator.
Again, seriously, be careful, the components will be hot."
Also this one came up.:
"Joe La Garbo, 30 years experience as an Automotive Technician. Employed at All Transmissions.
Written Jan 2, 2016
In the trade we use a in fared thermometer laser pointer and shoot it at different parts of the radiator to see how much the temperatures vary. If the temperatures vary by 30-50 degrees and the thermostat is working, chances are it's restricted. Without this you can also check it with the palm of your hand. First after the engine is warmed up shut it off and feel the upper and lower radiator hoses to see if the temperatures vary. If restricted chances are the upper hose will be very hot to the touch while the lower will be just warm. Once again that is if the thermostat is functioning properly. Also if you have access to different parts of the radiator core itself (the finned middle portion) feel it with your hand in different locations to feel for temperature variations. Be careful however because if you have an electric fan it can come on even with the car off. If temperatures vary, you can try to power flush or reverse flush the cooling system, but your best bet is to replace the radiator or have it boiled out by a Radiator repair shop, because at this point flushing is usually only a temporary fix. Without the year, make, model and engine size of your vehicle it's hard to give you a more accurate answer. But be sure your cooling system isn't leaking, thermostat is working and the electric fan(s) come on (if the car uses one). Good luck and hope this helps."
Other good tips here.
https://www.quora.com/How-do-I-know-if- ... ng-coolant
