AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Sat Nov 02, 2013 12:00 am
Hi Tom -
My least favorite task... but not impossible. It really comes down to getting your noggin down in there to see what / how it's connected to. Typically, the cable is hooked to a valve (to open the heater core) or a 'door' to divert air.
Look to see which control (from the driver's perspective) moves that cable. If it's the hot-to-cold dial / lever, then it;s gonna hook to a valve, typically in the engine bay, behind the engine, that allows coolant to enter the heater core. If it's the floor / dash / defrost lever / dial that controls where the air comes out, then it's gonna hook to a little lever on the side of the air diverter.
Again, it's going to be a function of removing the seats, crawling under the dash with a strong flashlight, mirror (and maybe even a camera ) to familiarize yourself with the controls. Have a helper move the controls while you feel the cable to its endpoint.
We have the Factory Service Manual here online, so when the time comes to do the work, we can link you to it.
