heater blower still not working?
bias
Car: 89 240sx hatch 93 240sx coupe
I did my swap a few months ago and now I have no air blowing from the vents. I checked all the wires and fuses and everything is getting voltage except for the wires going directly into the motor. When I hit the buttons on the heater control I heaar things moving but no blower? I checked with my other car and everything looks to be the same. Could I have goofed something up with the wiring, fuse box? Something? I'm going to be driving it soon and it's pretty cold so any info would be great. I did notice some plugs not attached but they were the same on the other car and it's blower motor works? I am completly clueless??????? I have been trying to figure it out all day?????? And I have to go back to work this weekend and I wil have to wait until monday to figure this out????? It's going to drive me crazy???????? LOL just a little pissed. But anyway any help would be great. Thanks in advance...
bias
Ok I checked everything and it looks like I'm not geting power to the blower motor fuses inside the car? Does anyone know the relay or fuse that hooks into this?
Bwana
Car: Denali
There are 2 blower motor fuses on the fuse block, both 15amp. They are fed from the #2 accessory relay which is located in the relay box below the air filter box in the engine compartment. I'd check that.
float_6969
Have you checked all of the fused and fusible links in the relay/fuse box behind the battery in the engine compartment?
bias
Bwana wrote:There are 2 blower motor fuses on the fuse block, both 15amp. They are fed from the #2 accessory relay which is located in the relay box below the air filter box in the engine compartment. I'd check that.
Thanks. I checked the box below the air filter and the relay was bad. Heat is working great
