aroche25 »
https://forums.nicoclub.com/aroche25-u177022.html
Wed Feb 01, 2012 2:49 pm
Recently I replaced my cars heater core hoses and did a complete coolant change. I did this because my heater wouldn’t work at all. Turns out the previous owner did a nice hack job and just kinked a hose between the 2 engine side heater core pipes. He also had just water in the coolant system, so as you can imagine I spent a good day purging it.
Well now I have heat and only heat. My AC stopped working at almost all speeds. The only time I can get COOL not cold air is if I’m coasting around 40-50mph. I even get heat when nothing is switched on at all. Another thing that has started to occur after those issues were addressed, is now I have a clear and very audible air/vacuum leak. The leak wasn’t there before I unkinked the heater hose and changed/purged the water to coolant.
My question is, is there some sort of switch that controls the heater/AC that is vacuum controlled? And if so where is it located. Judging by the way the previous owner addressed the heater I feel like I might be missing a vacuum line completely.
Let me know what you guys think.
