Hello fellow m37ers. I'm hoping someone out there can help me. My heated steering wheel crapped out just before the cold winter weather. I assumed it was a fuze issue, so didn't think much of it- just this weekend I went to check/replace the fuze- and it was intact- not shorted as I assumed. Just in case I replaced it with the spare, to no avail. Still no steering wheel heat. When I press the button, 8 hear a "click" somewhere behind the dash panel. Is there possibly another fuse location, or has anyone else had a problem similar and figured out a fix?
(Or is there a possibility my fuze diagram is mislabeled? I didn't check the other 15 amp fuses. Everything else appears to be working, and my "heater on" light at the switch also works.)
Alternatively, if someone can direct me to any wiring/ diagrams or dash removal threads (if this is at all advised) so I can attempt to fix this issue on my own, it would be highly appreciated...
