Heated side mirrors on S
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
Anyone know if the 2013 S would be pre-wired for heated side mirrors? I found heated OEM replacement mirrors at a good price and would like to do at least do the drivers side if its plug and play.
CapeCodChips
Car: '14 Nissan Rogue SV Gun Metal Grey
http://www.nissan-techinfo.com/TSB/TSB_ ... tsbType=AI
This link shows directions for installation of most accessories.
It gives instructions for replacement, not upgrade.
Pry the mirror off, if there are 2 black wires, you are prewired.
I ordered heated mirrors today, only $75, I'll ask at the dealer if they're prewired.
They would go on when you defrost rear window.
I won'tbe able to install for 2-3 weeks.
RyleyinSTL
Car: 2014 Nissan Rogue SL AWD w/ Premium Pkg.
Did you check the service manual? Might be wiring diagrams in there.
http://www.nicoclub.com/archives/nissan ... nuals.html
myriad46
Car: 2010 Rogue S 360 Edition
From what I've seen so far with recent Nissan models, if it's not an available option on the model you have, it's likely not prewired. Think about how much extra wire would be wasted globally. Even if it was more production cost to make many different harnesses, with the cost of metal, they would likely save quite a deal more, reducing the amount of wire in particular models by many feet. Similar to the accessory plug in the center console. The amount of materials saved over hundreds of thousands of units, adds up.
Return to “Rogue Forum”
