heated seat switch question
korbeano89
Car: 1997 Infiniti QX4
i took my wood console off to run wires for my gps and i unhooked the switches for everything and then hooked them back up and put ever thing together and i went to turn on my heated seat and the light doesn't even turn on,the passenger side works though, could the switch be shot? it happened the beginning of last summer so i didnt really mind not having it, but its getting cold out. the fuses are good, iv tried disconnecting and reconnecting it, ill probably try that again but i was wondering if i missed anything.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Might have to go back in there to see if you plugged in the switch at the very least. Does the seat heat up when the switch is pushed? If so the light may just be burnt out.
korbeano89
yea the seat doesn't warm up and im not positive but im kinda sure it wont do anything once i diss and reconnect it, but we'll see. Ill do it tomorrow.
Natedogg1701
Car: 2003 Nissan Pathfinder SE
maybe you pinched a wire or pulled on a harness on accident, i know when i take off my center console i have to be care ful not to pull on the harness that goes to my shifter, if its pulled or pushed on too much my overdrive button doesnt work, could be a bad switch, but id try moving wires around first, with all thw wires cramed in these vehicles its real easy for one to get pinched.
