newfhntr »
https://forums.nicoclub.com/newfhntr-u225699.html
Wed Jan 15, 2014 4:12 am
It is the relay, not the fuse
I has been a little while since I have had a chance to follow up on this. I followed the schematic and discovered that there is a relay in the passenger compartment fuse box that allows power to the heated seats only when the car is runing. The relay is located just above the fuses on the right side. The problem is that the previous owner removed the relay I checked the power going to the relay socket and everything looks correct. I then used a piece of wire to jump the relay contacts on the relay socket and the heated seats started working. So I know all I need is the relay.
Can someone send me a photo of the relay or tell me what color the relay is so that I can get the correct one?
Thanks,
Paul
