VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Dec 17, 2025 7:43 am
The blower on your ride should have a removable filter right over the fan, p/n 87383-9N00A. The prices for them (even online) are ridiculous, but you can reuse the frame and glue in material from a washable foam air filter to make a washable replacement. If the filter is missing and the screen in the blower assembly is clogged, I suggest removing the blower (have zip ties handy because that's how the ducts attach to the blower) and blowing back through it with compressed air.
To answer your other question, when peltier elements fail they usually go short or open, so if yours are working at all then they're fine. However, without proper ventilation, eventually something will fail, either a peltier or the controller. So if you have a clog, I'd lay off using it until you can address that. Nothing in those climate seat systems is cheap to replace.
