ARKQX33V6 wrote:Innovan, you changed out the cats, size different, explain the sizes, the pipe ID did you go bigger ID or smaller ID or is it the same? The pipe ID changes the volumetric gas sizes and could lead to erroneous O2 reading of rich vs. lean as the exhaust gases may have a different volume chamber to travel through. The sensors may be too slow in reaction time to what is happening there, it's doubtful that they are too fast. How old are the O2sensors in time and miles? At about 60-80 K miles they are responding too slow. Try to clean the surface of the O2sensor, this is just a brief fix.
The cats are OEM fit. Piping goes down to accomodate the sensors and from there is cut to put in the new piping (as stated in earlier post 2.25 inlet 2.5 out)
The driver side has been changed before by previous owner (cut and connect style)
ive come tot he conclusion that i sould just suck it up and pay 120 to get the new sensor (which i have) OEM replacement BOSCH from rock auto. Praying that will fix it and ive run it by the dealership. They state i should reflash my ECU as well for software upgrade (not sure if it will do any good)
I travel approx 310 km on 62 litres of 91 fuel. I think there is something wrong there. i should be getting more at least 350-400
insight?
