gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Wed Jun 10, 2009 9:02 am
i prefer leaving the wraps to downpipes and coating manifolds/turbine housings. the fiberglass wrap kind of disintegrates over time and not to mention is uglier/itchy to put on. plus it will make getting to bolts just that much more annoying when you're nicking your hands/wrap all up trying to tighten the nuts down. The wrap frays over time, and if you put it near the bolt holes you'll probably mess it up accessing the area with tools. Theres also other issues, like getting oil on the wrap (fire). i went with the DIY ceramic coating and that stuff holds up. recommend it if you're trying to go the slight extra step beyond wrapping in terms of application effort. It does help, but i've never taken temp readings of a manifold with wrap vs. nothing vs. ceramic, etc.
i think all the wrap said and done will be around $50. DIY ceramic coating is around the same price including buying sand for sand blasting, some HF tools, etc. Maybe closer to $60-75. Then the best option is to get it jet-hotted but that will run you around $200 iirc.
