Heat wrap the A/C line?
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
For you guys running the ac with an sr and a bottom mount turbo have you wrapped your AC line and has it made a difference in the cooling of it? My ac doesnt get near as cold as it did before with the ka! I live in the south and it gets quite toasty around here.
240sxguy05
Car: 95 s14 w/ s13 SR
I talked to an AC guy about the same thing, He said leave the factory stuff on there. if your talking about the main rubber line that comes from behind the block. try and use the factory stuff cause if you use heat wrap like thermo tec, it'll trap moisture in and not work as well since the other stuff was designed for it. I know what you mean i live in tx but my AC is just as cold as it was with my ka forever ago.
