heat will not work!!!!!!!!!!!!
A home for 1983–1989 300ZX owners!
ca240sxcoupe
Car: 1989 240sx w/ca18det, 1978 Datsun 280z
guys im in a bit of a pickle
i have flush out my heater core, changed the heater hoses to brand new ones and put a new thermostat in the 280 and i still cannot get the heat to work....the temperature will raise like normal and get to normal operating temperature, but when you turn the heat on the blower will come on but no heat will come out.....im stumped if anybody has a clue please let me know.....
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
there si a valve attached to the one heater line against the firewall, is the valve moving when you move the temp slesctor on and off? you said the blower is workign but nothing coming out? do you mean no hot air or no air at all? the cage on the blower motor is made of thin plastic and is known to disintigrate
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
If the temp is rising but you're not getting any heat, my guess would be is that you didn't burp the system. You'll have to get the air out of it. Let the car run w/o the air on and let it warm up w/o the radiator cap off and let the air burp out. Probably take 10-15 mins depending upon how much air is in it. You can also purchase a spill-free funnel that would adapt to the radiator cap and you could use that to flush it with.
http://www.drivewerks.com/cata...2.htm
Good luck with the solving the problem.
ca240sxcoupe
i didnt see a valve near either of the lines....but ill double check tomorrow....and yes i made sure all of the air is out of the lines....
Return to “300ZX (Z31) Forum”
