heat
88sammi
Car: s13 coupe
is it normal for the exhaust manifold to glow red after running it hard u can only see it at night its the stock manifold and turbo ?????
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
how hard are u running it?
88sammi
Car: s13 coupe
ohh i was on it full throttle for about 10 mins testing it out
progman
I was flooring my car for about 5 minutes on the highway and it was bright red. I could see the manifold through the heat wrap. the hot side of the turbo was bright red too.
88sammi
Car: s13 coupe
ok just makein sure i want the only one with that prob and i can only see mine at night not during the day
IggyEGuana
Car: 1986 200SX S12
I thought that only happened if the car was running lean. hmm
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
whats your timing set at? retarded timing has this effect also.
bentvalves
Car: 89 Silvia K's
check your timing but your straight.
even at 15dbtdc after hard pulls you will see exactly what you saw.
thats 900 degree celcius EGT's right there for ya.
