1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Wed Aug 24, 2005 4:31 pm
Dynamat is a sound deadener that you can line your whole car with to cut down on outside noise and reduce vibrations inside. And yes, this really helps your system sound better. You can get door kits, trunk kits, and just big sheets to cover the floor, roof, etc. It is fairly expensive though, so be ready to spend some money to do your whole car. I just got a trunk kit and another roll to do behind the rear seat where my subs were mounted and that really helped a lot.
There are cheaper alternatives, I think Summit has like a knockoff Dynamat, but Im not sure how good it is. I recommend it though, if you are building a good system it will be a smart investment.
