Heat stopped working...help!!!
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
hey guys, i have an 89 s13, i was driving to work two days ago, and i decided to warm my car up before i actually left, i go out to my car after about 10 minutes of letting it idle, and the temp gauge is still cold, so i start driving and it raise slowly but surely, so i turn the heat on, and it just starts blowing cold air at me and my *** is freezing....so i turn the heat off and just blow it to the window, by the time i got to the parking lot of my work, the temp gauge was all the way on H, i thought something was gonna blow up because this wierd noise started coming from the front of my car.
i've driven my car about 3 times since then and it still blows cold air, i have a/c and i know that works, my heat was working fine before that incident, i have no idea what it is, so if anybody could help me out, i'd appreciate it.
thanks-faizan
s13sr20chris
whoa, stop driving and do some checks real quick. that sounds like a dead ringer for low coolant level. pull the radiator cap off(engine cold) and check the level of coolant in the radiator.
DrifterXRPS13
i finally got around to checking, and it is low, what kind of coolant do you recommend i put in, it's cold here in chicago, and there's so many brands and choices, what should i use?
navysnail
any ethelene(sp?) glycol coolant will work (neon green color, not the red stuff). to top it off, open the bleed valve and fill the radiator, and you need to find the leak before you drive anymore if possible.
