C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Jan 07, 2004 4:28 am
Retaining heat in the turbine will make a turbo run more efficiently, but if you are only using a shield, it's not going to be significant. Shields trap a small amount of heat as there will ba a higher amount of heat trapped between the turbine housing and the shield. But some of the heat will still escape.
As far as my take on heat shields, I would focus more on protecting eveything else in the engine compartment from heat first. Retaining heat would not be a priority for me in looking at a heat shield. IN fact, I'd opt for the better looking heat shield before I cared how much heat it held in. If I was that concerned about retaining heat, I'd probably opt for a coating of some kind first. The stainless steel ones at Performance Turbochargers are nice. I'd have one, except, I'm too lazy to tap the turbine housing to accept bolts. And there's no way to tighten a nut and bolt if the heat shield is there. My cheap turbonetics heat shield will just have to do...
