Heat Shield/Y Pipe Repair Cost
richardinatlanta
Car: 2006 M35x
I think either my Heat Shield or Y Pipe are causing the dreaded rattling sound that many of you have experienced. I saw many threads about the diagnosis, but I did not see one in the cost of repair. Please let me know how much you paid to have either the Heat Shield or Y Pipe repaired. I have a 2006 M35x.
TXT
Car: 2006 M45 Sport
I have this issue and it's getting annoying. It doesn't sound terrible but I would like to fix it.
Also curious about repair cost.
merlinq2
Car: 2007 Infiniti M35x
TXT wrote:I have this issue and it's getting annoying. It doesn't sound terrible but I would like to fix it.
Can not be repaired, you will need to get a new y pipe- I had the same issue. Look at Ebay pipe was like $125 and $110 to install in Canada.
Good luck
TXT
Car: 2006 M45 Sport
Will a Megan Mid-pipe solve this issue?
finikM35
Car: 2007 M35x tech package
5/16 plenum spacer, element 114 exhaust, ztube,k&n, grounding kit, uprev tuned, D2 coilovers.
Mine was rattling bad, got new Y pipe from G37. No more rattle, sounds good. For AWD M you can get G37 z370 Y pipe
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
TXT wrote:Will a Megan Mid-pipe solve this issue?
No, it is the pipe between the headers and mid pipe that causes the problem and is arguably the biggest restriction in the stock system. Headers to Y pipe (problem) to mid pipe to mufflers.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
finikM35 wrote:Mine was rattling bad, got new Y pipe from G37. No more rattle, sounds good. For AWD M you can get G37 z370 Y pipe
I picked up a Ypipe that came off of a 2012 G37...Although I don't have an M35X, it still works well with the M35 sport...better low end tq...got mine for $100 :biggrin:
DeanM45
Just in case-No, these will not work on the 45 because the 45's have cats integrated into the pipe (35/37 pipes are too short for the 45).
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
^ true...the M45's require a little different set up. I think if I had the M45, I'd go custom from the Cats into a true dual exhaust -- leading to Megan axle backs :dblthumb:
Dean, didn't you customize your ypipe set up and remove your secondary cats?? I can't remember.
DeanM45
CPJ LB wrote:^ true...the M45's require a little different set up. I think if I had the M45, I'd go custom from the Cats into a true dual exhaust -- leading to Megan axle backs :dblthumb:
Yep: 2006-m45-y-pipe-the-beginning-t566657.html
Big improvement in performance and good improvement in mileage and still passes SMOG in Smognazifornia with no issues.
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
^ ok, now I remember!!! good job...more M45 guys should do this too.
richardinatlanta
Car: 2006 M35x
Thanks all for the information, but I am still looking for the total cost for the Y Pipe repair and the Heat Shield repair.
finikM35
Get used Ypipe for 70-100$ and replacing it is about another 50$ or you can do it yourself if you have ramps.
So thats about $150 if you go to the dealer you will pay something stupid like $1500
