Heat Shield
jajja88
Car: 2002 Infiniti Qx4
I am trying to change my catalytic converter on the passenger side for 2002 QX4. i was able to get the lower heat shield off and i got two bolts off for the top shield. there is one bolt that i cant access, there is access to get a ratchet there. the bolt is visible from the engine bay but i cant put a socket and a universal joint because of the chassis right behind it.
please help
EdBwoy
I'm guessing this bolt sits horizontally on the manifold? It's been a while since I did mine, but iirc:
Lots of penetrant followed by a gear wrench if you own one. Otherwise a little patience with your regular 10mm wrench should do it.
jajja88
This bolt is actually sits on the heat shied and then screwed into the catalytic converter.
bmfarmer.85
Car: 2003 Pathfinder SE
Flex head 10mm ratchet wrench.
jajja88
Thanks for in the input bmfarmer, do you recommend a long one or a short one? also is it accessible from under the car?
jajja88
