Heat Shield question
cstang1968
So i've removed a few heat shields already. The one covering the exhaust mani, the one that is close to the rear O2 sensor. My question is about the last heat shield down there. It doesn't seem to be bolted together. It looks like they just folded the sheet metal to form this shield. It is hooked around the pipe that is directly bolted to the exhaust mani. Do I just take some pliers and pull it off?
eddiec
Car: 91 S13
if you can't see any nuts or screws holding it on then yeah rip that pos outta there. i used a dremel to cut the brackets on the ones i removed.
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
so its a good idea to take off heat shields? what about the extra heat in the engine bay? or is this just to solve a noise problem...
240marcuSX
Car: E34 525i
E46 M3
yeah, ^ what he said, i would remove them, but i have a ka24e, and the plug wires are literally right there. when i get my hotshot, i might just get some header wrap and be done with it.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
The shield over my converter dropped down with the rest of the exhaust when I took it down. I wasn't sure if it was just stuck on top the cat, or if it rusted off of the car and was hangin' around or what. The only one bolted on was the very back one, nearest to the resonator. I have all of them that were under the car off, but I left the one covering up the exhaust manifold just in case.
ILikeMy240sx
Car: SR Power
Just remember not to park on top of lots of leaves or grass because the heat from the CAT will start a fire... watch out during fall
sXi
so.. keep the heat shield or not?
TheOne
Car: 93 240sx FB
i'd take it off if it was makin sounds(mine was, my brother's 95 was also).it really ain't gonna affect it much, cept maybe it can start some fires:).
sXi
without heatshield , BBQ?
sanioll
Car: Nissan 240SX SE
Toyota Camry
hmmm.. heatchield, it shields heat to some point.
What happens when heatshield heats up?? will dry leaves still catch fire??
