904CAL »
https://forums.nicoclub.com/904cal-u243288.html
Sun Oct 26, 2014 4:44 am
Thanks martronixx. The heater control valve under the hood is working (it's hot on both sides of the valve with the heat on, instead of hot on one side and cold on the other side), so I assume that means it's ok. Coolant and Freon are good (a/c will freeze you when it's hot outside). This started about two years ago, but recently I have heard a low slow popping/pecking sound at times that seems to come from the driver's side, but it's not the same as others have described online and as heard on YouTube.com, it's much slower and does not last long and it only happens once in a while. I will run the fan on high and switch from defog to floor to see if it makes the sound later and reply again. It seems like it would most likely be the air mix door actuator, but kind of doesn't make sense because the heat works normal when all the way up on 90 degrees, so I'm wondering if it could be an electronic component like a faulty sensor or something.
