Postby
sean8564 »
https://forums.nicoclub.com/sean8564-u23770.htmlSun Oct 30, 2005 1:25 pm
ok since it is now getting cold i would like to know how to get my heat to work all the line to heater core work cause i have heat when i drive on the freeway but the blower just dose not blow air it worked before the swap.
Postby
skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.htmlMon Oct 31, 2005 9:21 am
It might be a bad relay. Does your climate control unit have power? If not, check the relay marked "ACC" in the drivers side relay box. If you do have power, check the blower fuse (not sure where its at).
