i tried to but i my feet sweat alot lol240zac wrote:i have this too... i figured it to be heat from the exhaust because the catalytic converter is pretty much right below you. ive learned to live with it
my driving style is very non agrerssive, shift at 2.5 to 3, and from what Kristine says, she can feel it on the pass side too. i didnt drill any unnecessary holes, the only one i did was the for the clutch mc.onosqv wrote:Coming from the floor of the cockpit or can you actually feel ambient heat all over?
If it's coming from the floor - either your driving habits have changed significantly after doing the 5 speed swap (i.e. higher rpm's etc), or you drilled some extra holes or removed some heat shields, or it's been a while since you've driven ur vert and are just feeling it now...
In any case, this is what happens to guys who run turbo setups - most of them either deal w/ it, heat wrap/coat the downpipes, or heat wrap the chassis, like so:
ThermoTec Heat Wrap
You can get a smaller section for cheaper, this was just the first result I found.
Seriously tho -rj-, "SEARCH NOOB!"
its that metal thing the holds that rubber boot down right? yea i have thatonosqv wrote:Feeling from passenger side as well sounds like the heat is coming from the transmission then (turbo guys only have issues on the driver floor - passenger floor is like before).
Perhaps the 5-speed you have is just running hotter than other 5 speeds? Maybe low on transmission oil/fluid? The heat shield should take care of it.
And just for completeness sakes, did you install the 5speed transmission boot thingy that goes on the inside of the car below the shifter boot? Mostly to prevent transmission fluid smell in the cabin.
Why did you remove it?ishkabibble wrote:Do you have the heat shield on your catalytic converter? I removed mine, and the tunnel was always warm.
all the hot air being blown away from the radiator is getting blown under the car, this piece covers a pretty big hole under the counsol. not to mention the ambiant trans heat aswell.onosqv wrote:
that one. i'm pretty lost beyond that as to why a stock car would generate that much heat that you can feel it inside the cabin daily driving.
