Heat Extraction
89'ClubK's
Car: 89' Nissan 240SX
I used a DREMMEL Tool and cut out slits in my plug cover in order to let heat out. This will prolong the coil packs life. This is an idea for those who like to keep the cover. Put my hand over it, lets heat out excellent!Lot cheaper than the TOMEI for SR20.
http://img.photobucket.com/alb...4.jpg
tyrannix
Car: go big or go home
pic of it mounted FTW
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i am reluctant to cut holes in mine because whenever its off i get tons of sand and stuff around the plugs. its so annoying trying to vacuum out everything so i can take the plugs out safely. anyone else notice this? ah whatever.
looks good man, let us know how it works out for you. a little fresh paint and itll be good to go.
- tim
tyrannix
how are you getting sand on top of your engine?
dvd
can't u just make a ugly one out of a sheet of aluminum?
oversteer180
Car: 1990 Silver 240sx
heat ventilation...not extraction
tyrannix
you could stick some computer case fans on it to make it extraction (either run on a temp switch along with your electric fans, or with that nice brown wire +12 )
i would make a new one out of aluminum to mount fans on before i would hack apart a stocker tho (and maybe make a bunch and sell them )
oversteer180 wrote:heat ventilation...not extraction
f s t caz
Car: VG30ET D21 Extended Cab Pickup
i need to do that on mine as well. looks good
