nuts510 »
https://forums.nicoclub.com/nuts510-u34687.html
Mon Feb 16, 2009 4:05 am
I know when I was working for the Nissan dealership there was a service bulletin going around on automatic transmission coolers would deteriorate with time and quit transferring heat like they were supposed to, I would seriously seriously consider adding an inexpensive aftermarket transmission cooler you can get on a lot of the auto parts stores and you should only need a small to medium-sized one make a big difference but the number one thing that kills automatic transmission is cooking them they do not last like that, this may not fix your entire problem but at all sure help your transmission out that transferring the heat out of the fluid
