Keyan »
https://forums.nicoclub.com/keyan-u106942.html
Tue Jan 12, 2010 6:45 am
Just about every Nissan/Infiniti with auto climate control does this (Altima and Max do too at least). It runs the AC to pull moisture out of the air so you won't fog up as badly when the weather is cold. Same reason it runs on recirculate - to keep the moisture from your breathing etc from building up and causing the windows to fog up. You can generally turn it off, but just be aware that you can fog up more quickly.
It acts more like a dehumidifier in the winter than an AC, and it doesn't have much of any impact on the heat output from the heater, the air coming out is still very warm once the engine is warmed up.
