weg240sx »
https://forums.nicoclub.com/weg240sx-u81137.html
Thu Mar 27, 2008 12:46 pm
Ok I have a 1995 S14, well a week ago the heat/ac fan started to only run in position #4. 1,2,3 did not work. So I thought it was the fan control switch, I found a used control unit and replaced the one that I had. Everything pluged in perfectly, the only problem is that the heat/ac fan only works on position #4. I must be missing something, is there a fuse inbetween the switch and the motor; is the motor bad? Where cna I look and has anyone else had this problem?
