Don't worry... Worst case is that you unbolt the heads from your 91 motor and bolt them on to the bottom of the new 94/95 motor. From what I hear, the cut-out in the heads may be different for the sensors - but if they function the same way then it might be possible to adapt the 91 harness to a 94 style connector.
Heath
