Heads up display not working!!
luckytm
Car: anything exciting
is there anything you can do besides replacement, it seems to work like once or twice a month, could this be a short, or do they tend to go out often?
quiksilvia
Car: 95 s14 se
sometimes they need to warm up, but i would check all connections, fuse, whatevers clever, then maybe replace it
kansas240
Car: '00 Nissan Xterra 3.3
check the time control unit in the drivers kick panel, if that doesn't fix it, replace with another cluster. i rewired mine to be analog. description is on my homepage geocities.com/david_fruits
