Double E wrote:Good info here. How about Y34...what's the fill amount?
On Y34 too, it is more than 1 qt, so you have to buy two 1qt bottles.
Simple instructions - just make sure that you have a small,
clean funnel with a flexible rubber hose, or one of those squeeze handle pump bottles with a flexible hose.
0. Lift the car up keeping it reasonably level ... using a lift is safest, but not everybody has access to one.
Never do this work on just your jack from the trunk. Using jack-stands in
addition to the jack itself, is the absolute minimum, and essential for safety.
1. Open the fill entry bolt first - making sure you can get it off to avoid any potential problems with it later! Don't lose the washer.
2. Open the drain bolt and let the old gear oil drain out thoroughly. Don't lose the washer.
4. Clean the drain bolt and put it back on and tighten. Follow the torque specs (in our M manual section here).
5. Use the funnel and/or pump bottle to fill the differential with fresh 75W-90 gear oil all the way to the fill hole - you will need more than 1 qt to do this.
6. When the oil is filled to the level of the entry, put the entry bolt back on and tighten to the correct torque.
7. Lower car.
One of the easier DIY things to do on our car.
Also, remember that the X (AWD) models have more than one differential - since I have not done one of those, I am not sure of the exact procedure and whether it is more complicated or what the fluid spec is. The detailed service manuals here at NICO should give you the details.
Z
