heads up > analog guages?
89240sxdude
Car: carpentry
i know i need the harness to convert to analog guages but what part and how much of it? 1989 coupe
book-ends
Car: ???? Nissan 240SX coupe S13
You will need the sub-harness. It is the three plug harness that plugs into the back of the actual gauge cluster. On the other end it becomes two plugs, and that just plugs into the existing harness behind the dash.
I just did a digital to analog cluster AND dash swap last weekend. I hate the digital cluster and it was broken anyway.
Hope that helps.
yashin
Car: football, rugby
Just get the harness. And make sure you get it froma single cam not a twin cam, they don't interchange
89240sxdude
Car: carpentry
ok thanx. when your dash was out did it make a rev limiter sort of thing? cus mine does but im pretty sure its because it puts it in "safe mod" because the speed sensor circuit is bad it says judging by the codes from the ecu
book-ends
The dash or the gauge cluster? I never had any problem but I didn't drive the car without the gauge cluster installed. The CPU could very well see that the speed or tach circuit is not complete and thus flip to safe mode.
89240sxdude
Car: carpentry
the cluster yes. im just wondering if safe mode makes it have a rev limiter
