retho78 wrote:Thanks for the additional information. I will look into it and try to be careful when pulling the board out. Also, I noticed the OEM headliner fabric doesn't go over the side edges, not sure why they didn't over lap it a little and glue it on the back side of the board. I know it goes over the edges where the sunroof is but everywhere else it stops right at the edge.
I just took a look at my M headliner, you are correct, looking at the front edge along the windhield, it does not seem to foldover!
Another thing I noticed was the pockets the exit assist straps sit into...as well as the sunroof cavity area, they are sort off sunken in, for lack off better descriptions.
It gives me the appearance that the headliner & foam are custom moulded into these pockets!
Point is, looks like it would be difficult to mould in the new headliner & foam to those areas without wrinkling the fabric. I could be wrong, just going by appearance.
I never took the time to look at the headliner fabric carefully in my M, it is done nicely in like a tweed pattern. The headliner fabric samples I picked up for my old Caddy were the standard suede look type!
