Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Fri Jan 09, 2009 9:43 pm
I would check the box in the back for the brake lights as well. It's a black box with a bracket on one side if my memory serves. There are three different ones used on this generation Z, you will need another black one from an 87-89.
Turn on the lights, then the brights. Do the headlights rise up when the brights are on? By "the switch" that should have raised them but didn't, you meant he main stalk or the button beside the gauge cluster?
If you press the button and they raise up, then the motors and everything is fine but somebody disconnected a connector. Same for the brights.
