Headlights won't retract
Wolf240SX
Car: Tuning my car, working on friends cars
Hey has anyone had a problem with their headlights being stuck in the up position? I checked all the fuses they are ok. I checked all the wiring and each wire is geting the specified power. Also I checked out the headlamp retarctor switch and that is ok. Does anyone have a clue? Thanks
s0ldats
could it be the motor?
themadscientist
There is a switch on the dash of my wife's 180 below the steering wheel with a headlight icon on it, if you have a similar button push it and the lights should drop.
Wolf240SX
The motors are working fine and it is not the retractor switch (button with picture of head light). Has anyone had any experience with a relay malfunctioning?
themadscientist
There are several of them under the hood, it sounds like the next step to check.
b240
Try this: Disconnect the negative terminal on your battery. There is a red knob (i think its red , it is on mine) on the headlight motor , manually turn that and your headlight motor arm (whatever its called) should do a 360 and then they should be able to retract. Did you disconnect your battery for anything? This could be the problem. Anyways , im just trying to help. Good luck!
