Jdmstyles wrote:I've had a similar problem. one day my headlights wouldnt go up anymore unless I used the high beam. I replaced the flip up button or whatever you wanna call it (left of of the stalk) and it works again. The problem could be that the button's internals are corroding and what not. Either take your brothers and see if it works on yours or just go to the near by junk yard and throw one in your pocket :d
Hope it works.
i'll try my bros since i know his work, at a junkyard its hit or miss. i have a few of the buttons from junkyards but you can't tell if they work or not.
driftneil wrote:Perhaps you have the same problem as us all...But wired the polarity wrong.
a good idea but it isnt possible. the headlight wiring wasnt really tampered with at all and i'm 100 percent positive the wiring is fine since we were so meticulous about it
either tonight or tomorrow i'll try these suggestions- try headlight switch that i know for a fact works- try headlight button that i know for sure works - replace 25a fuse - reconnect brown wire
