headlights
kamikazestorm420
i have a 91 240sx and i wanted to know how to replace the lens?
silkk
Car: 94 B13
89 S13
07 S2000
you have to replace the whole housing because its a sealed beam.
if you're talking about removing it, there are 4 screws, 2 on top, and 2 on bottom and unscrew and it'll pop out.
kamikazestorm420
i replace the house headlight assembly .. but hten my driver side light is still out ..
anyone know how to fix it?
thepitt
Car: 1990 240sx
you could always check the fuse for the headlights. or should i say both of them . both the right side and left side have their own fuse. this happened to me once. i did the same with buying new headlights but one of them still wouldnt work. so just check the fuses.
240Kupe
Car: Racing, drifting
it is the headlight switch in the collumn. No prob to fix, expensive, but easy. I had same prob and that's how I fixed it.
i2ice4m3
Car: COUNTERSTRIKE!
would that switch affect left/right function? i thought it just affected high/low beam
S13ChucKAT
Car: asd
Ground may be corroded/rusted.. check your grounds, and then check your wires for frays..
240Kupe
yes, it is a combonation switch. My passenger headlight was out and I chased it around forever trying to find a fuse or loose wire; but finally someone told me it was the switch and that fixed it perfectly.
Shazoo
Car: 240's, Bass guitar, guitar, drums music
what about properly aiming the headlights, my aiming screws are rusty, where could i get new 1's? ps:i think i live near enjuku
