DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu Aug 27, 2015 8:55 pm
If you want HID level brightness, that's the only way to go.
Aiming your headlights will help your new lamps work better however, although you may find the adjusters rusted. There are two screw heads per each unit that lift and move the headlights, removing the middle cover and looking down the headlight body sides should reveal them. If rusted be sure to hit the whole thing with some penetrating lube and wait a bit- don't want to strip the heads which is very easy to do, or force the mechanism and bind it.
The OSM should also help you with the effort, found in the "everything you need to know about the Z32" sticky on the top of our page.
Good Luck!
