Headlights**
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
ODs_SE-R
Car: I have a 05 Altima SE-R with 78xxx miles on it. Im looking to make new friends and learn more about the car.. automatic to..
My Headlights are really dirty, any one have any suggestions or may know what i could do to clean them? I seems like its dirty from both in and out of light..
thanks guys..
ztommyx
tested on my dad's tacoma
original
halfway there..
done!
the driver side
original
done
no buffing here :cool:
my first time doing it...
both headlights took about an hour. though just a test, it turned out pretty good! :dblthumb:
ODs_SE-R
Good stuff man, looking good haha. mine arent that bad to start off with but just bothers me to have them looking like that. What did you use or do to make them look clear?.. Thanks for the pics haha
ztommyx
The concept is that you basically wet-sand the surface with varying grits and then you seal the headlight with with a 1:1 mixture of mineral spirits and helmsman clear gloss spar urethane by spreading it with a folded up blue Scott shop towel. The urethane mixture contains UV blockers that protects the finish, pretty much a clear coat.
ODs_SE-R
Oh ok, seems pretty simple. I appreciate all the info man. Thanks again. I'll prob be doing it sometime next week.. Needs it pretty bad
VQpwrdSE-R
Car: 2005 Code Red Nissan Altima SE-R
2013 Nissan Altima SV
Mine are pretty hideous. I bought the restoration kit from 3m and they were better. That is until I used a mothers headlight compound and it dried on the lens due to the hot summer sun. Some detailing shops will wetsand the headlights and do a good job for around $50.
Have you guys ever noticed how our healights taper back and recieve alot of UV rays? I can only imagine what the Jukes headlights will look like in 8 yrs as with te top set is directly ontop of the hood.
Buster_06_Alti
Car: 2006 Altima 3.5SE, Magnaflow Cat Back, K&N Cold AirIntake, Eibach Pro-Kit w/camber, Nissmo Sway Bars, Bully Dog GT Programmer
Pair of replacements for under $100 (free shipping with Amazon Prime). Great quality. Includes new bulbs. Quality is better than OEM. They also carry different projector styles in black and chrome if you want to pay a little more
http://www.amazon.com/2005-2006-Nissan- ... 321&sr=8-1
Return to “3rd Generation Altima Sedan (2002-2006)”
