headlights
korbeano89
Car: 1997 Infiniti QX4
does anyone know if 99.5-2000 qx4 the clear lens headlights work for a 97 qx4 and do you know where i can get them for a good price?
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
i dont know of anyone whose done it, most qx4 owners dont even realize the difference. But their the exact same it seems just the housing is clear. I have a 99.5, if you need any particular photos id be happy to take them for you
fueler
Car: 2 Nissan's
2 BMW's
the light *should* bolt up, however you will have to get the socket for the bulb and cut/splice that in because 97-99 have 9004 bulbs while the 99.5 switched to 9003 bulbs
they are completely different sockets and the 9004 bulb will not secure into the 9003 housing
Qxxx4
2012 Ford Mustang
oh snap i completely forgot about that. i nearly ordered the wrong HID kit before!
fueler
Car: 2 Nissan's
2 BMW's
i bought the wrong silverstars at walmart because of the discrepancy. if you look up bulb # for a 1999 qx4 (by the book or machine in the parts store), it lists 9004 and makes no mention of the change halfway through the year
they didnt want to accept my return because i had opened the package but i was able to prove that their lookup machine was wrong and they credited me.
krott5333
Car: 99 pathfinder se
Thats why whenever I'm looking for parts, I just tell them I have a 98 pathfinder (its a 99, but not a 99.5)
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
sorry to off topic but i just installed a headlights at my light is litterly hitting the sky. How do i adjust it.
fueler
Car: 2 Nissan's
2 BMW's
theres a wheel with teeth.... take a philips screwdriver and point it straight down againt the wheel and twist. thats the beam adjustment
UndeGuy
Car: 99.5 Pathfinder (I'm just borrowing it)
JonathanPrem wrote:sorry to off topic but i just installed a headlights at my light is litterly hitting the sky. How do i adjust it.
Wait, first, did you make sure the bulb is in correctly?
Assuming you have H4 bulbs, you should have three tabs sticking out, and they should line up in the socket. If any (or all) are mispositioned, it'll throw the aim off. One thing I found out LONG ago, if I managed to put the bulb in with one end of that wire holder between the bulb's base and the socket, the highlight will shine almost straight up or down... so you need to make sure that wire holder has BOTH ends on the outside of the bulbs base.
Once you've made sure those two aren't the case, then you can go for the screw fueler mentioned.
