1995Pathfinder »
https://forums.nicoclub.com/1995pathfinder-u4366.html
Sun Aug 29, 2004 12:58 am
Good point; I'll have to check. I checked over the wiring, pulled apart the dash, went under the dash looking for loose connections and everything seemed fine. The only thing I found was that the negative battery terminal cable was split and I replaced it. The car starts better as if the battery has a higher charge, but I am not sure whether the lights will intermittently shut off. I have the car in for state inspection, so I guess I have to wait. My luck, the lights won't work during inspection.
Thanks for the reply.
Mike
