13_SkylineSedan »
https://forums.nicoclub.com/13-skylinesedan-u228621.html
Fri Dec 13, 2013 4:00 pm
That doesn't make a lot of sense. Did this diagnosis come from a dealer service department? You may need a second opinion.
It's highly unlikely that both your ballasts went bad at the same time. If it's true that a "short" occurred then check all fuses (that's why they're there). If you find a bad fuse and turning on the headlights blows the replacement, then start tracing. Disconnect one headlight at a time until you find the fault.
If indeed you needed to replace just the ballast, the part from Infiniti costs about $375 (for one). I'm sure there are alternative manufacturers you could use.
In any case, do some more diagnosing before you start throwing on new parts.
