Headlights Problem
365240sx
I have a problem with my headlights not coming on. I have changed the headlight switch with a new one from autozone and I've checked the fuses and replaced the headlamps. Everything else works when I turn the switch but I get nothing fron the headlights(low beam and high beam). What else do I need to check?
Thank you
(I have already done search and didnt find anyhting to fix my problem)
GODCHSR
Car: 1996 Nissan 240sx
Sounds like a wiring problem then.
drifter92
Car: 1995 Nissan 240sx Small BLock Chevy V8 5.4L
1990 Nissan 240sx Coupe SOHC Auto Wrecked Project Car
did you check the harness that plugs into the bulbs? mine acts up sometimes but i just have to wiggle it around then it works for a few more months
biggjerryc
Car: 1992 240sx coupe
just follow everything. Get a voltmeter and start from square one. the headlight switch, the fuse box, the headlight relay ect.....
