TheOtherJeff wrote: ↑Mon Sep 25, 2017 1:37 pm
Hence my question: Can the halogen headlights be upgraded to have the same brightness as the Xenon ones?
There are lots of details when it comes to headlight upgrades, but I'll try to keep it simple. Halogens can be more or less upgraded to have about the same brightness as the Xenon ones, but it's not ideal. This is because the projectors designed for halogen bulbs are not the same as those for Xenon bulbs, so the light disperson patterns won't be optimized if you do a plug-and-play HID upgrade. However, I had the halogens originally and I didn't think they put out enough light, so I installed a plug-and-play HID kit. I felt it was a huge improvement over the stock halogens.
What about the high beams. Those are different too, aren't they. I haven't driven my new car at night much, so I can't say for sure, but I thought the high beams were less bright than what I was used to.
I've never really had an issue with my high beams, so I've kept them stock. If you do feel the need to upgrade them, I'd say to go with LED instead of HID. The HIDs will probably have a higher output, but they have a slight delay when it comes to warmup. LEDs are pretty much instant on at full intensity, which would be preferable in a high beam. This also comes into play when you need to flash the high beams.
The fog lights are yet another subject. I'm pretty sure that they changed the way they function. My were always on whenever the headlights were on before, but on the new car they go off when the high beams are on.
I believe that US DOT regulations dictate that fog lights must turn off automatically when high beams come on. I don't know if it's any different in Canada.
I haven't checked the color of them yet, but I always disliked how the bright Xenon headlights made the fog lights seem yellow and dull. Is there an easy way to make them match the color temp of the upgraded headlights?
Changing the color (temp) of the fog lights shouldn't be too difficult, and it looks like you should have several options there. You can go with the cheaper option of tinted halogen bulbs; or the pricier options of HIDs or LEDs. It shouldn't be hard to find the same color temp as the ones you pick for your low beams. Personally, if I were to change the color of my fog lamps, I think I'd go with a deeper yellow color for more contrast between the low beams and fog lights.
