Headlights flash intermittently, security?
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
So a few times now, after parking the car outside and locking/closing the doors, the headlights will both start flashing. It's not usually immediate, it usually kicks in a few minutes after I leave the car. There isn't any noise like an alarm, just the blinking lights.
Does anyone know if this is part of the factory security system? The PO had a Viper alarm/remote start installed but it wouldn't stop going off so I removed the controller (brain), but all the wiring is still in it. The thing was wired into everything so I didn't wanna mess anything up. Any ideas??
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Um. Yeah. Might have had your horn disconnected from the factory alarm system with the Viper system. I'd bet just about anything it's your hood latch sensor.
Ace2cool
If you wanna test the alarm and see if the horn works, lock the door with the window rolled down, and wait for the security light to go off, then reach in and unlock the door and open it. That will trigger the alarm. If it's just flashing lights, you've found your culprit.
t.mcginley.jr
1966 Ford Mustang
One problem... my horns don't work lol
But I'll still test this to see if the lights start flashing. Thanks Ace!
Is the security light supposed to flash consistently with everything shut and locked? Because mine does
Ace2cool
Nope. Supposed to flash quickly with the door open, and go solid when you lock it. Should go off after about 60 seconds. When it's flashing, that means there's a switch signalling an open compartment. Which, if the interior lights aren't on, is why it makes me think hood latch switch.
EDIT: When it goes from solid to off, that's when the system is officially "armed."
t.mcginley.jr
1966 Ford Mustang
I'll have to do some checking shutting doors and stuff. When you say the hood latch sensor, you mean the one attached to the driver side shock tower right?
Ace2cool
Yup.
t.mcginley.jr
1966 Ford Mustang
I haven't had time today to really check it (plus its raining on/off) but I noticed that I can get the security light to go solid sometimes. It seems like how I close my door affects it. When I close it a little harder it seems to go solid more often.
Ace2cool
Could be the door sensor then. Which is a bit harder to replace.
Alezooh
Car: 300zx 90 NA
it seems like my flashers are shorting out my dims or normal lights, from what ive read it could be the dimmer switch or maybe even just a relay/wiring issue. any ideas?
t.mcginley.jr
1966 Ford Mustang
Mine was definitely related to the factory security system. I removed the security box and haven't had a problem since. Since mine didn't honk anyway it was pretty useless
