vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Tue Jul 25, 2006 6:38 pm
if you tell me what you measure at the 5 terminals on the left motor or 10terminals on headlight timer I can tell you what is happening.(measure with lights off as you push retraction button with it intially in closed position). if , for example, you were testing terminal 1 (brown-yellow) on headlight timer, youd test between the termninal and ground. if you get 12volts, the terminal is 12v positive. if nothing, test between the terminal and 12volts positive. if you get 12 volts, the terminal is ground. if you dont get 12 volts either time, you know the terminal has no charge.
