Headlights 2011 M37
KiLIAkLoWn
Car: M37S
Having issues with the driver side. The main bulb comes on when first started then flickers out. I'm thinking its a bad bulb I'm almost at 100k. Has anyone used PIAA G3 LED? it keeps saying that it is longer than OEM bulb so to check clearance.
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
Have you tried swapping the bulbs to see if the issue moves? I'd try that first. No sense replacing a bulb and then it turns out to be the ballast.
Ilya
More than likely the ballast. I had flickering in my driver side as well, it was the ballasts. I replaced both at the same time.
Hughes W.
Car: 2016 Infiniti QX50 3.7L AWD
KiLIAkLoWn wrote:
Fri Jun 21, 2019 2:15 pm
I just switch out HID to LED, have to change the ballast also.......
