adjust them up to your desired height and unplug the motors... thats the free way to do it.Caboose-1 wrote:I want to restrict the movement on my headlights so that they come up at about half the height as normal. Is there a way to do that?
nice... i've always just pulled the plug on em. i'll have to try thatLeash wrote:How do you want the settings of the headlights? Do you want the motors to still be operational? Or non?
Unplug the motors and just turn the knobs until they are at the height you want.
If you want them to rotate while maintaining the height you want, then you need to adjust the arm of the motor. loosen the bolt and adjust accordingly and re tighten.
This is a write up of a headlight conversion but there are some pictures on the location of the arm and what it looks like. http://www.cardomain.com/ride/792500/3
The motors will still run in a 360 motion though.
